Saltar al contenido principal
Dell Precision M4700 Optical Drive Replacement
Qué necesitas
  1. Dell Precision M4700  Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M4700  Optical Drive Replacement: paso 2, imagen 1 de 2 Dell Precision M4700  Optical Drive Replacement: paso 2, imagen 2 de 2
    • Remove the two 3mm screws that secure the base cover to the computer with a Phillips #00 screwdriver.
    • Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Dell Precision M4700  Optical Drive Replacement: paso 3, imagen 1 de 2 Dell Precision M4700  Optical Drive Replacement: paso 3, imagen 2 de 2
    • Remove the 3mm screw that secures the optical drive to the computer with a Phillips #00 screwdriver.
    • Slide the optical drive out.
Conclusión
Una persona más ha completado esta guía.
Dylan
Miembro Desde 10/30/19
361 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 445
