Saltar al contenido principal
Dell Precision M3800 Fan Replacement
Qué necesitas
  1. Dell Precision M3800 Fan Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Precision M3800 Fan Replacement, Back Cover: paso 1, imagen 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Fan Replacement: paso 2, imagen 1 de 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Fan Replacement, Fan: paso 3, imagen 1 de 2 Dell Precision M3800 Fan Replacement, Fan: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
  4. Dell Precision M3800 Fan Replacement: paso 4, imagen 1 de 3 Dell Precision M3800 Fan Replacement: paso 4, imagen 2 de 3 Dell Precision M3800 Fan Replacement: paso 4, imagen 3 de 3
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
  5. Dell Precision M3800 Fan Replacement: paso 5, imagen 1 de 2 Dell Precision M3800 Fan Replacement: paso 5, imagen 2 de 2
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 1,264
