Saltar al contenido principal
Dell Precision 5510 Keyboard Replacement
Qué necesitas
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: paso 1, imagen 1 de 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Keyboard Replacement: paso 2, imagen 1 de 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: paso 3, imagen 1 de 2 Dell Precision 5510 Keyboard Replacement, Fans: paso 3, imagen 2 de 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: paso 4, imagen 1 de 2 Dell Precision 5510 Keyboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Precision 5510 Keyboard Replacement: paso 5, imagen 2 de 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: paso 6, imagen 1 de 2 Dell Precision 5510 Keyboard Replacement, Battery: paso 6, imagen 2 de 2
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Precision 5510 Keyboard Replacement: paso 7, imagen 2 de 2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: paso 8, imagen 1 de 2 Dell Precision 5510 Keyboard Replacement: paso 8, imagen 2 de 2
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: paso 9, imagen 1 de 1
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: paso 10, imagen 1 de 1
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: paso 11, imagen 1 de 1
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: paso 12, imagen 1 de 1
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: paso 13, imagen 1 de 1
    • Pull keyboard out and replace.
Conclusión
Colin Hunter
Miembro Desde 03/31/22
121 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-1, Harley Spring 2022 Miembro de IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Miembros
4 Guías creadas
Un comentario
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 52
Todo El Tiempo: 2,369
