Saltar al contenido principal
Dell Latitude E7470 SSD Replacement
Qué necesitas
  1. Dell Latitude E7470 SSD Replacement, Open cover: paso 1, imagen 1 de 3 Dell Latitude E7470 SSD Replacement, Open cover: paso 1, imagen 2 de 3 Dell Latitude E7470 SSD Replacement, Open cover: paso 1, imagen 3 de 3
    • Begin by removing the 8 screws circled in red on the photo opposite with a Philips # 0 screwdriver.
    • Next, using the iFixit Opening Picks, lift the cover up from the dock connector. Unclip it gently.
  2. Dell Latitude E7470 SSD Replacement, Changing the SSD: paso 2, imagen 1 de 3 Dell Latitude E7470 SSD Replacement, Changing the SSD: paso 2, imagen 2 de 3 Dell Latitude E7470 SSD Replacement, Changing the SSD: paso 2, imagen 3 de 3
    • After removing the cover, the SSD slot is on the bottom right, right next to the battery.
    • Make sure you have grounded yourself before you start handling. There is a huge risk of damaging components. Use an antistatic wrist strap.
    • To remove the SSD, simply remove the single screw that holds it. Lift the SSD to a 30-degree angle and pull it from its slot.
Conclusión
To reassemble your device, follow the instructions in reverse order.
6 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Hyperion
Miembro Desde 12/13/15
2,004 Reputación
3 Guías creadas
8 comentarios
Does the M.2 interface in this board support NVMe M.2 SSD’s?
Kinetik - Contestar
It does! It has only one plastic piece (I forgot what the proper term is), not 2.
Luke Johnson -
It’s not working for me with Kingston nvme NV1
Ravi Bhargava - Contestar
If no ram or ssd do ya got to put windows 10 back on I got no recover usb .or a dell recovery usb with 10 or what was original on it .its a e7470
Mike Heiss - Contestar
Without RAM you cannot start the computer, it is an essential component.
Without SSD you have no storage so you can't install Windows.
Hyperion -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 71
Ultimos 30 días: 189
Todo El Tiempo: 20,893
