Saltar al contenido principal
Dell Latitude E7450 Memory (RAM) Replacement
Qué necesitas
    • Before performing this task, make sure you turn off the computer and disconnect every external drive from it, whether it's a USB drive, power charger, or wireless adapter.
    • Remove battery and base cover from the computer.
  1. Dell Latitude E7450 Memory (RAM) Replacement, Open retention clips: paso 2, imagen 1 de 1
    • Open the retention clips away from the memory chip.
  2. Dell Latitude E7450 Memory (RAM) Replacement, Remove memory chip: paso 3, imagen 1 de 1
    • Remove the memory chip from the computer.
    • Put a new memory chip in the memory socket.
    • Push the memory chip until the clips lock it. If a second memory chip needs to be installed, repeat steps 1 through 6.
    • Replace the pre-removal parts in descending order.
    • Install the battery and base cover back on the computer.
Conclusión
Hezekiah Brown
Miembro Desde 02/11/21
6,169 Reputación
49 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 1,281
