Saltar al contenido principal
Dell Latitude E6320 Memory (RAM) Replacement
Qué necesitas
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery, secure SD card, and base cover from the computer.
  1. Dell Latitude E6320 Memory (RAM) Replacement, Open rentention clips to remove memory chips.: paso 2, imagen 1 de 1
    • Pry the retention clips away from the memory module until it pops up.
  2. Dell Latitude E6320 Memory (RAM) Replacement, Remove memory chip from computer.: paso 3, imagen 1 de 1
    • Remove the memory module from the computer.
    • Insert the memory module into the memory slot.
    • Press the clips to secure the memory module to the system board.
    • Install the base cover, secure SD card, and battery to the computer.
Conclusión
Hezekiah Brown
Miembro Desde 02/11/21
6,169 Reputación
49 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 391
