Saltar al contenido principal
Dell Latitude E5400 Memory Upgrade / Replacement
Qué necesitas
  1. Dell Latitude E5400 Memory Upgrade / Replacement, Remove battery: paso 1, imagen 1 de 1
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: paso 2, imagen 1 de 2 Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: paso 2, imagen 2 de 2
    • Losen all four screws and remove the backpanel.
    • Remove the backpanel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Dell Latitude E5400 Memory Upgrade / Replacement, change/upgrade the memory: paso 3, imagen 1 de 1
    • Now you can upgrade or change the memory.
    • NOTE: If the laptop doesnt boot after the upgrade, make sure the ram is fully inserted. Still doesnt boot? Try another memory stick.
Conclusión
Una persona más ha completado esta guía.
Robin Koch
Miembro Desde 03/25/17
289 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 2,179
