Qué necesitas
Starting on the right side of the computer, use a plastic scribe (inserted into the indent) to pry up the hinge cover. Lift the bottom edge of the cover away from the keyboard going from the right to the left, and then pull the cover up and away from the display to remove it.
Insert the tabs on the top edge of the cover into the slots under the bottom edge of the display.
Press from left to right until the cover snaps into place, ensuring that the edges of the cover line up with those on the palm rest.
