Saltar al contenido principal
Dell Latitude D531 Coin Cell Battery Replacement
Qué necesitas
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching a connector on the back panel of the computer.
    • Remove the battery.
  1. Dell Latitude D531 Coin Cell Battery Replacement, Loosen screw on memory module/coin-cell battery cover.: paso 2, imagen 1 de 1
    • On the bottom of the computer, loosen the captive screw on the memory module/coin-cell battery cover and remove the cover (see image).
  2. Dell Latitude D531 Coin Cell Battery Replacement, Use scribe to lift up coin-cell battery; replace battery.: paso 3, imagen 1 de 1
    • Insert a plastic scribe into the guide on the side of the coin-cell battery compartment, and ease the battery out of the compartment.
    • When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
    • Tighten the screw on memory module/coin-cell battery cover.
    • Install the battery.
Conclusión
Hezekiah Brown
Miembro Desde 02/11/21
6,169 Reputación
49 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 118
