Saltar al contenido principal
Dell Latitude D430 Wireless Adapter Replacement
Qué necesitas
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: paso 1, imagen 1 de 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: paso 1, imagen 2 de 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: paso 1, imagen 3 de 3
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: paso 2, imagen 1 de 2 Dell Latitude D430 Wireless Adapter Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: paso 3, imagen 1 de 1
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: paso 4, imagen 1 de 3 Dell Latitude D430 Wireless Adapter Replacement: paso 4, imagen 2 de 3 Dell Latitude D430 Wireless Adapter Replacement: paso 4, imagen 3 de 3
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: paso 5, imagen 1 de 2 Dell Latitude D430 Wireless Adapter Replacement: paso 5, imagen 2 de 2
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: paso 6, imagen 1 de 1
    • Pull the wireless adapter out away from where it was connected.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 511
