Saltar al contenido principal
Dell Latitude 9410 2-in-1 SSD Replacement
Qué necesitas
  1. Dell Latitude 9410 2-in-1 SSD Replacement, Base Panel: paso 1, imagen 1 de 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 SSD Replacement: paso 2, imagen 1 de 2 Dell Latitude 9410 2-in-1 SSD Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 SSD Replacement: paso 3, imagen 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: paso 3, imagen 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: paso 3, imagen 3 de 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: paso 4, imagen 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: paso 4, imagen 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: paso 4, imagen 3 de 3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 SSD Replacement: paso 5, imagen 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: paso 5, imagen 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the 2 mm screw, loosening the bracket that covers the SSD.
    • Carefully lift the off the bracket.
    • The bracket is attached to the laptop and cannot be removed completely.
  6. Dell Latitude 9410 2-in-1 SSD Replacement: paso 6, imagen 1 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: paso 6, imagen 2 de 3 Dell Latitude 9410 2-in-1 SSD Replacement: paso 6, imagen 3 de 3
    • Grip the SSD and pull directly backward until the SSD releases from its port.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 45
Todo El Tiempo: 922
