Introducción
Use this guide to replace the coin cell battery (CMOS) of the Dell Latitude 9410 2-in-1.
If your computer runs slow, receives “Booting Error” messages, or loses BIOS settings when turned off, the CMOS may need to be replaced. The typical CMOS lifespan is 3-5 years, so if you're experiencing issues related to a failing CMOS, it's likely time to replace it. Be sure to check the troubleshooting page before moving forward with replacement.
Qué necesitas
Carefully peel back and remove the black tape around the top left corner of the motherboard.
