Saltar al contenido principal
Dell Latitude 9410 2-in-1 CMOS Battery Replacement
Qué necesitas
  1. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, Base Panel: paso 1, imagen 1 de 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 2, imagen 1 de 2 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 3, imagen 1 de 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 3, imagen 2 de 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 3, imagen 3 de 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: paso 4, imagen 1 de 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: paso 4, imagen 2 de 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: paso 4, imagen 3 de 3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 5, imagen 1 de 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 5, imagen 2 de 3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Grip the CMOS cable as close as possible to the plug, and gently pull directly backwards, in the direction of the cables, until the CMOS cable disconnects from the motherboard.
    • If the cable is hard to pull out by hand, use tweezers to get a better grip on the cable connector.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 689
