Saltar al contenido principal
Dell Latitude 6430u Memory chip (RAM) Replacement
Qué necesitas
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery, SD card & base cover from the computer, respectively.
  1. Dell Latitude 6430u Memory chip (RAM) Replacement, Pry open clips; remove memory chip/module from connector.: paso 2, imagen 1 de 1
    • Pry the securing clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
    • Insert the memory module into the memory socket.
    • Press the memory module down until it clicks into place.
    • Install the base cover, SD card, & battery on the computer, respectively.
Conclusión
Hezekiah Brown
Miembro Desde 02/11/21
6,169 Reputación
49 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
Miembros de 43
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 355
