Saltar al contenido principal
Dell Inspiron 15-5567 Back Cover Replacement
Qué necesitas
  1. Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Back Cover Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-5567 Back Cover Replacement: paso 2, imagen 2 de 2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Back Cover Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15-5567 Back Cover Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15-5567 Back Cover Replacement: paso 3, imagen 3 de 3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 2,476
