Saltar al contenido principal
Dell Inspiron 15-3521 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: paso 1, imagen 1 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: paso 1, imagen 2 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: paso 1, imagen 3 de 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: paso 2, imagen 1 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: paso 2, imagen 2 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: paso 2, imagen 3 de 3
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: paso 3, imagen 1 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: paso 3, imagen 2 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: paso 3, imagen 3 de 3
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: paso 4, imagen 1 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: paso 4, imagen 2 de 3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: paso 4, imagen 3 de 3
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
Conclusión
28 personas más completaron esta guía.
Andrew Dippre
Miembro Desde 10/13/14
2,902 Reputación
7 Guías creadas
Equipo
Clemson, Team 3-1, Benson Fall 2014 Miembro de Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 64
Todo El Tiempo: 33,319
