Saltar al contenido principal
Inglés
Español
Paso 2
Locate the two hard drive screws, located on the left-hand side of the hard drive casing. Loosen and remove these screws using a phillips head screw driver PH0. Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
Remove the Hard Drive
  • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
  • Loosen and remove these screws using a phillips head screw driver PH0.
  • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
Insertar traducción aquí
