Saltar al contenido principal
Dell Inspiron 14 5100 Touch Pad Replacement
Qué necesitas
  1. Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 3 de 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Touch Pad Replacement: paso 2, imagen 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement: paso 2, imagen 2 de 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Touch Pad Replacement, Battery: paso 3, imagen 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Touch Pad Replacement: paso 4, imagen 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: paso 4, imagen 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: paso 4, imagen 3 de 3
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
  5. Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: paso 5, imagen 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: paso 5, imagen 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: paso 5, imagen 3 de 3
    • Disconnect the touchpad cable attached to the motherboard.
    • Be careful lifting the Flat Flex Cable (FFC) connector as it is quite fragile.
  6. Dell Inspiron 14 5100 Touch Pad Replacement: paso 6, imagen 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement: paso 6, imagen 2 de 2
    • Peel off the tapes securing the touchpad to the keyboard assembly.
  7. Dell Inspiron 14 5100 Touch Pad Replacement: paso 7, imagen 1 de 1
    • Remove the four screws securing the touchpad to the keyboard assembly using the Phillips #0 screwdriver.
  8. Dell Inspiron 14 5100 Touch Pad Replacement: paso 8, imagen 1 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: paso 8, imagen 2 de 3 Dell Inspiron 14 5100 Touch Pad Replacement: paso 8, imagen 3 de 3
    • Remove the three screws securing the touchpad bracket to the keyboard assembly using the Phillips #0 screwdriver.
    • Lift the touchpad bracket.
  9. Dell Inspiron 14 5100 Touch Pad Replacement: paso 9, imagen 1 de 2 Dell Inspiron 14 5100 Touch Pad Replacement: paso 9, imagen 2 de 2
    • Lif tthe touchpad and replace with the new touchpad.
    • Make sure to guide the touchpad cable along with the touchpad to avoid damaging the parts.
    • Lift the touchpad at an angle from under the touchpad bracket to avoid damaging the touchpad or the touchpad bracket.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,061
