Saltar al contenido principal
Dell Inspiron 14 5100 Power Adapter Port Replacement
Qué necesitas
  1. Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 1 de 3 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 2 de 3 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 3 de 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Power Adapter Port Replacement: paso 2, imagen 1 de 2 Dell Inspiron 14 5100 Power Adapter Port Replacement: paso 2, imagen 2 de 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: paso 3, imagen 1 de 2 Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: paso 3, imagen 2 de 2
    • Disconnect the power-adapter port cable from the motherboard.
  4. Dell Inspiron 14 5100 Power Adapter Port Replacement: paso 4, imagen 1 de 2 Dell Inspiron 14 5100 Power Adapter Port Replacement: paso 4, imagen 2 de 2
    • Remove the two screws securing the power adapter port to the keyboard assembly using the Phillips #0 screwdriver.
  5. Dell Inspiron 14 5100 Power Adapter Port Replacement: paso 5, imagen 1 de 1
    • Remove the power adapter port and remove it from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 41
Todo El Tiempo: 3,119
