Saltar al contenido principal
Dell Inspiron 14 5100 Heat Sink Replacement
Qué necesitas
  1. Dell Inspiron 14 5100 Heat Sink Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 1 de 3 Dell Inspiron 14 5100 Heat Sink Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 2 de 3 Dell Inspiron 14 5100 Heat Sink Replacement, Dell Inspiron 14 5100 Disassembly: paso 1, imagen 3 de 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Heat Sink Replacement: paso 2, imagen 1 de 2 Dell Inspiron 14 5100 Heat Sink Replacement: paso 2, imagen 2 de 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Heat Sink Replacement, Heat Sink: paso 3, imagen 1 de 1
    • Unscrew the four screws securing the heat sink to the motherboard using the Phillips #0 screwdriver.
  4. Dell Inspiron 14 5100 Heat Sink Replacement: paso 4, imagen 1 de 2 Dell Inspiron 14 5100 Heat Sink Replacement: paso 4, imagen 2 de 2
    • Lift the heatsink and replace it with a new one.
    • When adding the new heatsink, make sure to add thermal paste to avoid overheating the CPU when in use.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 659
