Saltar al contenido principal
Dell Inspiron 13-7352 Battery Replacement
Qué necesitas
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 13-7352 Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 13-7352 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: paso 2, imagen 1 de 2 Dell Inspiron 13-7352 Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: paso 3, imagen 1 de 1
    • Gently remove the battery from the rest of the device.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 personas más completaron esta guía.
3 comentarios
Last I looked up for a different model there was a video..
pc2053 - Contestar
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - Contestar
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 24,988
