Saltar al contenido principal
Dell Inspiron 11-3168 Battery Replacement
Qué necesitas
  1. Dell Inspiron 11-3168 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 11-3168 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Battery Replacement: paso 2, imagen 1 de 3 Dell Inspiron 11-3168 Battery Replacement: paso 2, imagen 2 de 3 Dell Inspiron 11-3168 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Battery Replacement: paso 3, imagen 1 de 2 Dell Inspiron 11-3168 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 11-3168 Battery Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Battery Replacement: paso 5, imagen 1 de 3 Dell Inspiron 11-3168 Battery Replacement: paso 5, imagen 2 de 3 Dell Inspiron 11-3168 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the battery.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 personas más completaron esta guía.
2 comentarios
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Phillip Dennis - Contestar
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
Matthew Roomsburg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 936
