Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Partes
No se especificaron partes.
  1. Close the computer and turn it over, with the bottom of the computer facing up.
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Remove the nine 7.6mm PH0 screws on the cover.
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Use a plastic opening tool to remove the cover from the computer.
    • Use a plastic opening tool to remove the cover from the computer.
  4. Remove the three 4.7mm PH0 screws that secure the battery to the computer.
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  6. Remove the hard drive cable from the battery.
    • Remove the hard drive cable from the battery.
  7. Lift the battery from the computer.
    • Lift the battery from the computer.
  8. Peel off the adhesive strap from the hard drive.
    • Peel off the adhesive strap from the hard drive.
  9. Use a PH0 screwdriver to remove the 2 3.9 mm PH0 screws on the hard drive.
    • Use a PH0 screwdriver to remove the 2 3.9 mm PH0 screws on the hard drive.
  10. Lift the hard drive to free it from the laptop.
    • Lift the hard drive to free it from the laptop.
  11. Remove interposer from the hard drive.
    • Remove interposer from the hard drive.
  12. Use pull tab to remove hard drive cable from motherboard.
    • Use pull tab to remove hard drive cable from motherboard.
Conclusión
Muhammad Erchid
Miembro Desde 09/10/18
1,051 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 74
