Introducción
Many Dell laptops, including the Dell G15 5511, are prone to hinge problems due to the way they are tightened. Over time, loose or overtightened hinges can make a "cracking" sound, and, if not fixed, the strain can spread and cause cracks to form along the display frame or even damage internal components.
This guide demonstrates how to fix these hinge issues on your Dell G15 5511 so you don't end up with lasting damage in the future.
Before you begin, make sure your laptop is powered off and unplugged from the charging adapter.
Qué necesitas
Hold the power button down to shut off your laptop.
Flip the laptop over while securing the bottom cover and set it down with the top cover facing up and the hinge screws facing you. You now have access to the eight M2.5x4(4mm) hinge screws.
Use a Phillips #0 screwdriver to tighten any loose screws, but don't overdo it.
Carefully open and close the top cover of the laptop to test the hinges and adjust the screws accordingly, based on your personal preference for how tight you want it to be.
Slide your spudger or opening tool along the edges of the frame, starting with the left or right side.
You should hear each side unclip as you slide the opening tool across. After you've detached the sides, slide the opening tool along the top and then finally the bottom.
Remove the screen bezel.
To finish the repair, follow these instructions in reverse order.
