Saltar al contenido principal
Dell Chromebook 5190 I/O board Replacement
Qué necesitas
  1. Dell Chromebook 5190 I/O board Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 I/O board Replacement: paso 2, imagen 1 de 3 Dell Chromebook 5190 I/O board Replacement: paso 2, imagen 2 de 3 Dell Chromebook 5190 I/O board Replacement: paso 2, imagen 3 de 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 I/O board Replacement: paso 3, imagen 1 de 2 Dell Chromebook 5190 I/O board Replacement: paso 3, imagen 2 de 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 I/O board Replacement: paso 4, imagen 1 de 2 Dell Chromebook 5190 I/O board Replacement: paso 4, imagen 2 de 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 I/O board Replacement: paso 5, imagen 1 de 2 Dell Chromebook 5190 I/O board Replacement: paso 5, imagen 2 de 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 I/O board Replacement: paso 6, imagen 1 de 3 Dell Chromebook 5190 I/O board Replacement: paso 6, imagen 2 de 3 Dell Chromebook 5190 I/O board Replacement: paso 6, imagen 3 de 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 I/O board Replacement, I/O board: paso 7, imagen 1 de 2 Dell Chromebook 5190 I/O board Replacement, I/O board: paso 7, imagen 2 de 2
    • Disconnect the first purple I/O cable by lifting upwards and pulling away from the I/O connector.
  8. Dell Chromebook 5190 I/O board Replacement: paso 8, imagen 1 de 2 Dell Chromebook 5190 I/O board Replacement: paso 8, imagen 2 de 2
    • Disconnect the second purple I/O cable by lifting upwards and pulling away from the I/O connector.
  9. Dell Chromebook 5190 I/O board Replacement: paso 9, imagen 1 de 3 Dell Chromebook 5190 I/O board Replacement: paso 9, imagen 2 de 3 Dell Chromebook 5190 I/O board Replacement: paso 9, imagen 3 de 3
    • Unscrew the two (M2x4) screws on the I/O bracket.
    • Lift off the I/O bracket.
  10. Dell Chromebook 5190 I/O board Replacement: paso 10, imagen 1 de 2 Dell Chromebook 5190 I/O board Replacement: paso 10, imagen 2 de 2
    • Unscrew the three (M2x4) screws on the I/O board.
    • Dismount the I/O board.
Conclusión
Denise Cano
Miembro Desde 02/10/22
617 Reputación
4 Guías creadas
Equipo
Gateway, Team 1-3, Pee Spring 2022 Miembro de Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 241
