Saltar al contenido principal
Dell Chromebook 3100 Bottom Cover Replacement
Qué necesitas
  1. Dell Chromebook 3100 Bottom Cover Replacement, Remove Bottom Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 Bottom Cover Replacement, Remove Bottom Cover: paso 1, imagen 2 de 2
    • Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
    • Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
Conclusión
Jon
Miembro Desde 08/18/13
3,921 Reputación
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 433
