Saltar al contenido principal
Dell Chromebook 3100 2-in-1 Input Output Board Replacement
Qué necesitas
  1. Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 2, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 2, imagen 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Battery: paso 3, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 4, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 4, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 5, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 5, imagen 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Input/Output Board: paso 6, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement, Input/Output Board: paso 6, imagen 2 de 2
    • Remove all four 4 mm screws that secure the IO bracket and IO board using a Phillips #1 screwdriver.
  7. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 7, imagen 1 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 7, imagen 2 de 3 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 7, imagen 3 de 3
    • Flip open the retaining flaps on the two cable connectors in the IO board.
    • Disconnect the 30-pin and 40-pin IO board cables from their connectors on the motherboard.
    • Disconnect the IO cable from the system board by pulling it out of its socket.
  8. Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 8, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Input Output Board Replacement: paso 8, imagen 2 de 2
    • Slowly pull out the input/output board from the laptop.
Conclusión
Muhammad Ali
Miembro Desde 09/02/21
352 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Pee Fall 2021 Miembro de Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
Miembros de 5
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 47
Todo El Tiempo: 952
