Saltar al contenido principal
Dell Chromebook 3100 (Touch) Motherboard Replacement
Qué necesitas
  1. Dell Chromebook 3100 (Touch) Motherboard Replacement, Detach Bottom Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 (Touch) Motherboard Replacement, Detach Bottom Cover: paso 1, imagen 2 de 2
    • Unscrew the nine PH#0 captive screws on the bottom of the device.
    • Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
  2. Dell Chromebook 3100 (Touch) Motherboard Replacement, Motherboard: paso 2, imagen 1 de 2 Dell Chromebook 3100 (Touch) Motherboard Replacement, Motherboard: paso 2, imagen 2 de 2
    • Disconnect the daughterboard data cables.
  3. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 3, imagen 1 de 2 Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 3, imagen 2 de 2
    • Pull the daughterboard power cable out of its socket parallel to the motherboard.
  4. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 4, imagen 1 de 2 Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the M2x3 screw and cover, and disconnect the antenna cables.
    • Note: be careful on reassembly. Antenna connectors can be troublesome and are easy to damage.
  5. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 5, imagen 1 de 1
    • Disconnect the touchpad, keyboard, and speakers where shown.
  6. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the four M2x4 screws, as well as the cover over the LVDS cable (top right).
  7. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 7, imagen 1 de 2 Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 7, imagen 2 de 2
    • Detach the LVDS cable.
    • The cable is held down with adhesive. Don't be shy about pulling it off the motherboard.
  8. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 8, imagen 1 de 1
    • Lift the motherboard out from the left side and pull away from the body of the chromebook.
    • During reassembly, it is much easier to insert the motherboard without the IO shield attached. The IO shield is easily inserted after the motherboard is in place.
  9. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 9, imagen 1 de 2 Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 9, imagen 2 de 2
    • Apply lateral force to the IO shield to break the adhesive holding it to the motherboard.
    • Save this IO shield to put on the new motherboard.
  10. Dell Chromebook 3100 (Touch) Motherboard Replacement: paso 10, imagen 1 de 1
    • During reassembly, make sure to include a thermal pad on the CPU. Usually you can reuse the one from the previous motherboard, but it's best to have access to a new pad in case the old one is not usable.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 598
