Saltar al contenido principal
Dell Chromebook 3100 (Touch) Battery Replacement
Qué necesitas
  1. Dell Chromebook 3100 (Touch) Battery Replacement, Detach Bottom Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 (Touch) Battery Replacement, Detach Bottom Cover: paso 1, imagen 2 de 2
    • Unscrew the nine PH#0 captive screws on the bottom of the device.
    • Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
  2. Dell Chromebook 3100 (Touch) Battery Replacement, Unplug the battery: paso 2, imagen 1 de 2 Dell Chromebook 3100 (Touch) Battery Replacement, Unplug the battery: paso 2, imagen 2 de 2
    • Pull carefully, but firmly, on the battery cable until it becomes detached.
  3. Dell Chromebook 3100 (Touch) Battery Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Remove these three M2x5 screws and take the battery out
    • If your replacement battery doesn't come with a cable, you will need to remove the cable from the old battery before disposing of it.
    • DO NOT throw batteries in the trash. Take them to a proper battery recycling center.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 210
