Introducción
Are you having trouble connecting your Chromebook to the internet? You network card may be damaged, and in need of replacement! Follow this easy guide to quickly get your computer connected to the internet again.
Qué necesitas
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
