Saltar al contenido principal
Dell Alienware 18 Battery Pack Replacement
Qué necesitas
  1. Dell Alienware 18 Battery Pack Replacement, Before You Begin: paso 1, imagen 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Battery Pack Replacement, Remove the base cover screws: paso 2, imagen 1 de 1
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Battery Pack Replacement, Slide the Cover: paso 3, imagen 1 de 1
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Battery Pack Replacement, Prelude: paso 4, imagen 1 de 1
  5. Dell Alienware 18 Battery Pack Replacement, Remove the battery screws: paso 5, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two screws securing the battery to the computer base.
  6. Dell Alienware 18 Battery Pack Replacement, Disconnect the battery cable: paso 6, imagen 1 de 1
    • Disconnect the battery cable from its connector by pulling it straight up from its socket.
  7. Dell Alienware 18 Battery Pack Replacement, Remove the battery: paso 7, imagen 1 de 1
    • Remove the battery from its recess.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
darrius
Miembro Desde 03/26/18
5,213 Reputación
30 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
42 Miembros
1,987 Guías creadas
Un comentario
This is the wrong computer being displayed here.
Tru-B -DaT - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 1,262
