Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
DROCON Ninja Propeller Replacement
  1. DROCON Ninja Propeller Replacement, Battery: paso 1, imagen 1 de 3 DROCON Ninja Propeller Replacement, Battery: paso 1, imagen 2 de 3 DROCON Ninja Propeller Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
    Pregunta a FixBot
    Agregar Comentario
  2. DROCON Ninja Propeller Replacement, Propeller: paso 2, imagen 1 de 2 DROCON Ninja Propeller Replacement, Propeller: paso 2, imagen 2 de 2
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
    Pregunta a FixBot
    Agregar Comentario
  3. DROCON Ninja Propeller Replacement: paso 3, imagen 1 de 3 DROCON Ninja Propeller Replacement: paso 3, imagen 2 de 3 DROCON Ninja Propeller Replacement: paso 3, imagen 3 de 3
    • Take note of the letter printed on the bottom of the propeller. Make sure the replacement propeller has the same letter.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
4Guía Comentarios
can we buy an extra battery?
Orlay Gutierrez - Contestar Compartir
can we buy an extra battery for the roconDC-014
hi i have the red & bleu drocon dc-014 & wold like to order the white drocon dc-014 white drone or white body cover
tank you! & happy new year!!!
claude demers - Contestar Compartir
i both drocon dc-014 blue & red wold like by the white drocon dc-014 or uper casse
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 39
Todo El Tiempo: 2,304
