Saltar al contenido principal
DR.J Professional HI-04 Motherboard Replacement
Qué necesitas
  1. DR.J Professional HI-04 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 DR.J Professional HI-04 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 DR.J Professional HI-04 Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Motherboard Replacement: paso 2, imagen 1 de 3 DR.J Professional HI-04 Motherboard Replacement: paso 2, imagen 2 de 3 DR.J Professional HI-04 Motherboard Replacement: paso 2, imagen 3 de 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Motherboard Replacement: paso 3, imagen 1 de 2 DR.J Professional HI-04 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Motherboard Replacement: paso 4, imagen 1 de 2 DR.J Professional HI-04 Motherboard Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Motherboard Replacement: paso 5, imagen 1 de 2 DR.J Professional HI-04 Motherboard Replacement: paso 5, imagen 2 de 2
    • Squeeze the tab against the connector, and pull the connector straight out from the socket.
    • The cable will come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Motherboard Replacement: paso 6, imagen 1 de 2 DR.J Professional HI-04 Motherboard Replacement: paso 6, imagen 2 de 2
    • Lift the motherboard from the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
    • Pull the cable from the connector.
  7. DR.J Professional HI-04 Motherboard Replacement: paso 7, imagen 1 de 2 DR.J Professional HI-04 Motherboard Replacement: paso 7, imagen 2 de 2
    • Set down the motherboard safely.
Conclusión
Baron Dutra
Miembro Desde 11/01/23
825 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Miembro de UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Miembros
5 Guías creadas
Un comentario
Baron, thanks for the guide. My projector took a tumble and landed right on the back where the input/power plug is. I plugged it back in and the red light turns on, but that's all. I don't hear any loose parts and it definitely wasn't overheated. Any ideas on what it could be? Trying to get the right screwdriver to open it up later this week.
Socev - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 109
