Saltar al contenido principal
DR.J Professional HI-04 Lens Replacement
Qué necesitas
  1. DR.J Professional HI-04 Lens Replacement, Lens: paso 1, imagen 1 de 3 DR.J Professional HI-04 Lens Replacement, Lens: paso 1, imagen 2 de 3 DR.J Professional HI-04 Lens Replacement, Lens: paso 1, imagen 3 de 3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lens Replacement: paso 2, imagen 1 de 3 DR.J Professional HI-04 Lens Replacement: paso 2, imagen 2 de 3 DR.J Professional HI-04 Lens Replacement: paso 2, imagen 3 de 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Lens Replacement: paso 3, imagen 1 de 2 DR.J Professional HI-04 Lens Replacement: paso 3, imagen 2 de 2
    • Gently lift the black flap off from the base of the lens.
  4. DR.J Professional HI-04 Lens Replacement: paso 4, imagen 1 de 2 DR.J Professional HI-04 Lens Replacement: paso 4, imagen 2 de 2
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
  5. DR.J Professional HI-04 Lens Replacement: paso 5, imagen 1 de 2 DR.J Professional HI-04 Lens Replacement: paso 5, imagen 2 de 2
    • Unscrew the cover of the lens.
Conclusión
Kory Lajoie
Miembro Desde 11/01/23
127 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Miembro de UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 39
Todo El Tiempo: 234
