Saltar al contenido principal
DCC-3200 Faulty Power Cord Replacement
Qué necesitas
  1. DCC-3200 Faulty Power Cord Replacement, Faulty Power Cord: paso 1, imagen 1 de 1
    • First, please be sure that the device is unplugged and that there is no water in the reservoir.
    • Check the power cord for frays or cracks.
  2. DCC-3200 Faulty Power Cord Replacement: paso 2, imagen 1 de 1
    • If the cord appears fine, please flip the device upside-down and unscrew the 4 screws on the bottom.
  3. DCC-3200 Faulty Power Cord Replacement: paso 3, imagen 1 de 1
    • Remove the bottom panel and unclip the power cord from the panel.
  4. DCC-3200 Faulty Power Cord Replacement: paso 4, imagen 1 de 1
    • With the front facing towards you upside down, to the top left of the circular hotplate is a beige circuit board with two screws on either side holding it in. Please unscrew them.
  5. DCC-3200 Faulty Power Cord Replacement: paso 5, imagen 1 de 1
    • Carefully remove the circuit board and unplug the gray ribbon wire that is plugged into it.
  6. DCC-3200 Faulty Power Cord Replacement: paso 6, imagen 1 de 1
    • Check to see if the power cord is connected properly to the circuit board.
  7. DCC-3200 Faulty Power Cord Replacement: paso 7, imagen 1 de 1
    • Strip the wire and twist with the other or solder it back on.
Conclusión
Una persona más ha completado esta guía.
Hamad Khan
Miembro Desde 03/04/16
385 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 2,017
