Saltar al contenido principal
Cuisinart Smart Stick CSB-75 Power Switch Board Replacement
Qué necesitas
  1. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: paso 1, imagen 1 de 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: paso 1, imagen 2 de 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement, Power Switch Board: paso 1, imagen 3 de 3
    • Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
    • After prying these off, the screws will be exposed.
  2. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 2, imagen 1 de 2 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 2, imagen 2 de 2
    • Remove three 13.3 mm Phillips PH#2 screws.
  3. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 3, imagen 1 de 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 3, imagen 2 de 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 3, imagen 3 de 3
    • Pry open Cuisinart using a plastic opening tool.
    • The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Make sure to pry open near the clips of the smart stick for easy opening.
  4. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 4, imagen 1 de 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 4, imagen 2 de 3 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 4, imagen 3 de 3
    • Unscrew the 4 screws on the inside.
    • Remove 2 13.3mm Phillips PH#2 screws.
    • Remove 2 17.5 mm Phillips PH#2 screws.
    • Unscrewing these screws will isolate the switch board.
  5. Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 5, imagen 1 de 2 Cuisinart Smart Stick CSB-75 Power Switch Board Replacement: paso 5, imagen 2 de 2
    • Refer to these steps on Soldering to replace the switch board in the smart stick.
    • Be careful when soldering. Metal components will become very hot.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 16-2, Wollert Fall 2015 Miembro de USF Tampa, Team 16-2, Wollert Fall 2015
USFT-WOLLERT-F15S16G2
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 89
Todo El Tiempo: 1,539
