Introducción
This guide demonstrates how to replace the power cord on your Crain 775 Jamb Saw.
Qué necesitas
Use a Phillips #2 screwdriver to remove the eight screws securing the saw housing:
Four 20 mm screws
Two 50 mm screws
Two 55 mm screws
Use a Phillips #2 screwdriver to remove the two screws securing the power cord grommet retention bracket.
Use a Phillips #2 screwdriver to loosen the two screw terminals securing the power cord wires to the main switch.
Remove the power cord wires from the main switch.
Remove the power cord and power cord grommet from the rest of the saw body.
