Introducción
This guide will show you how to replace the glide pads for a Corsair Dark Core RGB PRO SE mouse if the mouse doesn't glide as smoothly as it used to or it gets stuck when gliding.
Make sure to check out the troubleshooting page before replacing the glide pads and before starting make sure to cover the sensor to prevent damage.
Qué necesitas
Use the heat gun on the bottom of the mouse to loosen the glue on the pads.
Una persona más ha completado esta guía.
