Saltar al contenido principal
Corsair Dark Core RGB PRO SE Battery Replacement
Qué necesitas
  1. Corsair Dark Core RGB PRO SE Battery Replacement, Battery: paso 1, imagen 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: paso 1, imagen 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Apply heat with a heat gun or blow dryer to the glide pad near your palm.
    • Carefully remove the glide pad with a spudger.
    • Remove the two screws from beneath the glide pad using a T5 Torx screwdriver.
  2. Corsair Dark Core RGB PRO SE Battery Replacement: paso 2, imagen 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: paso 2, imagen 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the palm rest by pulling it outwards.
    • Pull up where the latches are.
    • Take your time and work around the area to avoid snapping the plastic latches
    • Remove the top buttons by using tweezers and pushing the tabs.
  3. Corsair Dark Core RGB PRO SE Battery Replacement: paso 3, imagen 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: paso 3, imagen 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: paso 3, imagen 3 de 3
    • Remove the two screws that were underneath the left and right buttons using a Phillips #00 screwdriver.
    • Place the spudger in between the shell and the bottom of the mouse, releasing the latch.
    • Do not try to remove the top shell by pulling it up as it might break the latch.
    • Remove the six screws using a Phillips #00 screwdriver.
  4. Corsair Dark Core RGB PRO SE Battery Replacement: paso 4, imagen 1 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: paso 4, imagen 2 de 3 Corsair Dark Core RGB PRO SE Battery Replacement: paso 4, imagen 3 de 3
    • Remove the circuit board by pushing the two latches holding it in place in opposite directions.
    • Unplug the ribbon cable by pushing the black connector holding it in place.
    • Disconnect the battery cord by pulling it up.
  5. Corsair Dark Core RGB PRO SE Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery with a spudger or your fingers.
Conclusión
4 personas más completaron esta guía.
2 comentarios
Where can I buy a spare battery? I don't see them in stores.
Ilya - Contestar
I found some models that are compatible on Aliexpress
carlus -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 42
Ultimos 30 días: 184
Todo El Tiempo: 3,098
