Introducción
If you're having issue with the external sound on your Contixo V8 (model number V8X), you can troubleshoot the issue here; this guide will show you how to replace the internal speaker. You will need two iFixit plastic opening tools and a soldering iron or gun with a small tip. Please see this guide for information on soldering and desoldering connections within your device. A plastic spudger may also prove useful, but the iFixit opening tools could be used instead. You may also want to consider using an anti-static wrist strap and anti-static mat to protect yourself from accidental electric charges when working on your device; see this guide for information on how to use these items.
Qué necesitas
Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
Lift the face of the tablet.
Press the soldering tip to the connection point to detach the speaker from the motherboard. See this guide for information and tips on soldering and desoldering.
You have now detached the internal speaker and the new speaker is ready to be attached.
