Introducción
A 3AG fuse is a glass - bodied fuse designed to break an electric circuit if the current exceeds safety levels in a Commodore 64 device
Qué necesitas
Paso 1 Removing screws
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
1. Remove three 6.75mm ph2 screw heads from the casing
1. Detach the multi-colored wire bundles that's connected to the motherboard
2. Find the 3AG fuse located next to the joystick ports and On/Off switch
3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
4 personas más completaron esta guía.
