Saltar al contenido principal
Partes
No se especificaron partes.
  1. Follow the camera replacement guide to access the battery.
  2. The battery is connected to the back side by a strong adhesive.
    • The battery is connected to the back side by a strong adhesive.
    • The battery may bend during this process.
    • Be careful not to damage the wires or the black tab attached to the battery.
    • Be careful not to allow the battery to bend any more than necessary. Battery acid leakage is possible.
    • Pry the battery off the back side with a plastic opening tool.
  3. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  4. Pull the tape off the side with the wires and circuit piece. Pull the tape off the side with the wires and circuit piece. Pull the tape off the side with the wires and circuit piece.
    • Pull the tape off the side with the wires and circuit piece.
  5. Have someone who is skilled in soldering to perform this step. Be careful not to destroy the motherboard or other parts of device. Desolder the wires connecting the battery to the motherboard from the contact points on the motherboard.
    • Have someone who is skilled in soldering to perform this step.
    • Be careful not to destroy the motherboard or other parts of device.
    • Desolder the wires connecting the battery to the motherboard from the contact points on the motherboard.
Conclusión
4 personas más completaron esta guía.
Kevin Finney
Miembro Desde 22/03/15
553 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-4, Williams Spring 2015 Miembro de Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Miembros
8 Guías creadas
Como puedo conseguir el repuesto de mi tabletas epik
Reyshaliz - Contestar
A little then moderate skill is necessary if you are somewhat mechanically inclined shouldn't be too problematic. But as far as this gentleman's directions and steps perform the task with no problems and tablet works now. Thank you Kevin Finney and three others my four-year-old daughter Hazel is happy again thanks to you.
Collins Hill
Great Smoky Mountains , TN.
Elivia Hill - Contestar
I think these are great instructions for fixing this issue!
If you'd be interested in going a step further…I've been trying to find out how to safely remove the charge port! I know how to solder the replacement onto the board but I can't confirm the best way to detach the old port!?
My god daughter would appreciate another video! :)
JenBcute - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 12
Últimos 30 Días: 44
Todo El Tiempo: 3,709
