Saltar al contenido principal
Cleaning Inside Your Inspiron
Qué necesitas
  1. Cleaning Inside Your Inspiron, Removing Side Panel Screws: paso 1, imagen 1 de 1
    • First attach your Anti Static wrist band to both yourself and the chassis of the computer. You may need to move your wrist band around to different areas to make it easier while dismantling and that's fine. Just remember to have it connected at all times when handling the parts.
    • Now we can begin taking the PC apart. To start simply remove the two case screws on the back.
  2. Cleaning Inside Your Inspiron, Sliding Side Panel Cover Off: paso 2, imagen 1 de 1
    • Next we are going to lay the tower on it's right side (side where motherboard is attached) and slide the cover off.
  3. Cleaning Inside Your Inspiron, Checking Front Ports: paso 3, imagen 1 de 1
    • Before moving on, make sure that nothing is plugged into the ports on the front of the PC. If there is anything plugged into them, please remove them now.
  4. Cleaning Inside Your Inspiron, Removing the Face Cover: paso 4, imagen 1 de 1
    • While putting LIGHT downward pressure on the side of the face cover (red), apply gentle upwards pressure to the three clips (Orange).
  5. Cleaning Inside Your Inspiron, Removing the Face Cover: paso 5, imagen 1 de 2 Cleaning Inside Your Inspiron, Removing the Face Cover: paso 5, imagen 2 de 2
    • Once the three clips are free from the internal case you will see the face panel swing down. Simply lift the front of the PC up while it is laying on it's side, and the face cover will unhook from the other side.
  6. Cleaning Inside Your Inspiron, Removing HDD & Optical Drive: paso 6, imagen 1 de 2 Cleaning Inside Your Inspiron, Removing HDD & Optical Drive: paso 6, imagen 2 de 2
    • Next remove the three screws holding the HDD and Optical Drive in place. It is very important that you DO NOT remove the drives yet as they are still plugged into the motherboard.
  7. Cleaning Inside Your Inspiron, Disconnecting the Cords: paso 7, imagen 1 de 2 Cleaning Inside Your Inspiron, Disconnecting the Cords: paso 7, imagen 2 de 2
    • Next we need to unplug the cables from the back of the Optical Drive and HDD. Do not grab the wires to pull. Get a firm grip on the hard plastic plugin and gently rock the cord side to side until it comes free.
    • Keep in mind there are two cords for your Optical Drive, and two cords for your HDD to make a total of four that need to be unplugged.
  8. Cleaning Inside Your Inspiron, Removing the Optical and HDD Drives: paso 8, imagen 1 de 1
    • Now that the screws are removed and cables unplugged. Very carefully lift the drives out. They slide directly up and out. Make sure to set your drives with the HDD facing up like you see in Red Box. To reassemble your drives carefully line them up in the space with the orange box outlined.
    • Then carefully set them inside the PC. It lines up perfect and comes close to the SATA cords on the motherboard. Make sure nothing is getting pressed down underneath when reassembling.
  9. Cleaning Inside Your Inspiron, Remove Those SATA Cords: paso 9, imagen 1 de 1
    • Before you use the canned air or Air Compressor on the inside, make sure to remove those pesky SATA Cords as they tend to grab and hold onto pet hair and other dust chunks. Be careful when reassembling as the ports are numbered. 0 is the first SATA port your motherboard will load so make sure your HDD is plugged into 0.
    • Your Optical Drives plugs into the number 1 which is right next to your 0 port. 1 will be loaded second so make sure your Optical Drive is connected to that. Otherwise when you turn your PC on, it will not load your Operating System, which is the Interface you see when using your PC.
  10. Cleaning Inside Your Inspiron, Removing Heat Sink Fan: paso 10, imagen 1 de 3 Cleaning Inside Your Inspiron, Removing Heat Sink Fan: paso 10, imagen 2 de 3 Cleaning Inside Your Inspiron, Removing Heat Sink Fan: paso 10, imagen 3 de 3
    • Note: We are NOT removing the heat sink in this guide as that requires cleaning of its own and reapplying thermal paste. It is VERY important you check the second photo in this step to make sure you are taking the correct screws out.
    • Remove the four screws around the edge of the fan and make sure to unplug the power wire to the fan (Photo #3). Once unplugged and screws removed, you may gently take out the heat sink fan.
  11. Cleaning Inside Your Inspiron, Begin Cleaning: paso 11, imagen 1 de 3 Cleaning Inside Your Inspiron, Begin Cleaning: paso 11, imagen 2 de 3 Cleaning Inside Your Inspiron, Begin Cleaning: paso 11, imagen 3 de 3
    • With everything out of our way we can begin cleaning. You may clean in any order you wish. When cleaning the Heat Sink Fan (Red) DO NOT let the fan spin. When cleaning the Heat Sink Grill (Orange) you may find it best to use cotton. Start in the center and pull to the outer edge to clean.
    • Make sure you spray underneath your motherboard. There is a small gap between your chassis and motherboard shown in the blue marker. Dust, pet hair, and other debris like to hide under there. To finish up make sure to spray the back peripheral ports and the front ports. Also spray down system fans making sure not to let them spin!
  12. Cleaning Inside Your Inspiron, Finishing Up: paso 12, imagen 1 de 1
    • If you would like to clean the Front Case, simply take a damp cloth and wipe it down. Make sure it fully dries before reassembly otherwise you risk water damage to the PC.
    • If cleaning the Optical and HDD Drive be very careful not to drop or slam the HDD as you will damage your DATA and OS. Meaning when you reassemble the PC, you will not have an Operating System to come back to. Also be careful not to spray to close to parts as condensed air has high moisture content at close range.
Conclusión
Congratulations! Wasn't so hard after all huh? Now that you are done cleaning everything, just put it back together. Follow the steps above in reverse if you get stuck, and should you run into problems and need help, please feel free to ask me!
2 personas más completaron esta guía.
Gabriel
Miembro Desde 04/10/17
380 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 19
Todo El Tiempo: 1,876
