Introducción
This guide shows how to remove and replace the glued-on grip face pad for the Clarke Floor Sander 07014A.
The process involves prying the old grip face off of the base plate with a putty knife, removing the adhesive residue, and adhering a new grip face on.
Qué necesitas
Twist and pull the dust bag collar to disconnect it from the elbow pipe.
Remove the dust bag.
Lock the handle in place by pulling the lock lever upwards.
Test the lock by wobbling the handle and making sure that it is not loose.
Use a powered wire wheel brush, putty knife, or scraper to remove large chunks of adhesive.
Alternatively, spray the entire surface with Xylene or other solvent that dissolves adhesive, let it soak for ten to fifteen minutes and the adhesive will peel off with minimal effort.
Remove any remaining residue with a fine wire wheel brush or coarse (50~100) grit sander. The final surface should feel smooth.
Clean the surface with some isopropyl alcohol.
Carefully line up the grip face pad to the base, ensuring that all the edges line up.
Press the right edge of the pad (with exposed adhesive) onto the base.
Pull the adhesive liner from behind the pad and remove it to expose the remaining adhesive.
Look at the liner you just pulled out and make sure it hasn't ripped and left some of the liner on the back of the pad.
16 personas más completaron esta guía.
