Saltar al contenido principal
Casio CTK-3200 Speaker Replacement
Qué necesitas
  1. Casio CTK-3200 Speaker Replacement, Center Front Panel: paso 1, imagen 1 de 2 Casio CTK-3200 Speaker Replacement, Center Front Panel: paso 1, imagen 2 de 2
    • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
  2. Casio CTK-3200 Speaker Replacement: paso 2, imagen 1 de 1
    • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
    • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
    • If the panel is not easily removable, make sure all the screws are removed from the back.
  3. Casio CTK-3200 Speaker Replacement, Side Panel: paso 3, imagen 1 de 2 Casio CTK-3200 Speaker Replacement, Side Panel: paso 3, imagen 2 de 2
    • Remove all eight 10 mm Phillips #1 screws that secure the side panels.
  4. Casio CTK-3200 Speaker Replacement: paso 4, imagen 1 de 1
    • Carefully remove one side panel at a time from the top of the keyboard and place it above the keyboard, making sure not to sever any connections between the yellow-colored mainboard and the side panels.
    • If the panels are not easily removable, make sure all the screws are removed from the back.
  5. Casio CTK-3200 Speaker Replacement, Speaker: paso 5, imagen 1 de 2 Casio CTK-3200 Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Carefully remove the four 10 mm Phillips #1 screws that secure the speaker.
  6. Casio CTK-3200 Speaker Replacement: paso 6, imagen 1 de 1
    • In order to replace the speaker, desolder the wire at the two locations indicated in the photo.
    • To install the the new speaker, you will solder the same wires to the marked locations.
    • In order to safely and correctly solder the new wire, please refer to the soldering guide.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bentley
Miembro Desde 10/23/24
219 Reputación
2 Guías creadas
Equipo
Cuesta, Team 10-4, Krynen Fall 2024 Miembro de Cuesta, Team 10-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G4
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 35
