Saltar al contenido principal
Casio CTK-3200 Key Replacement
Qué necesitas
  1. Casio CTK-3200 Key Replacement, Center Front Panel: paso 1, imagen 1 de 2 Casio CTK-3200 Key Replacement, Center Front Panel: paso 1, imagen 2 de 2
    • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
  2. Casio CTK-3200 Key Replacement: paso 2, imagen 1 de 1
    • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
    • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
    • If the panel is not easily removable, make sure all the screws are removed from the back.
  3. Casio CTK-3200 Key Replacement, Side Panel: paso 3, imagen 1 de 2 Casio CTK-3200 Key Replacement, Side Panel: paso 3, imagen 2 de 2
    • Remove all eight 10 mm Phillips #1 screws that secure the side panels.
  4. Casio CTK-3200 Key Replacement: paso 4, imagen 1 de 1
    • Carefully remove one side panel at a time from the top of the keyboard and place it above the keyboard, making sure not to sever any connections between the yellow-colored mainboard and the side panels.
    • If the panels are not easily removable, make sure all the screws are removed from the back.
  5. Casio CTK-3200 Key Replacement, Key: paso 5, imagen 1 de 2 Casio CTK-3200 Key Replacement, Key: paso 5, imagen 2 de 2
    • Target which key(s) need to be replaced and unscrew the 10 mm Phillips #1 screws for the targeted section(s).
    • There are five different sections of white keys, you can tell the sections apart by the small gaps between them where the screws are attached.
  6. Casio CTK-3200 Key Replacement: paso 6, imagen 1 de 3 Casio CTK-3200 Key Replacement: paso 6, imagen 2 de 3 Casio CTK-3200 Key Replacement: paso 6, imagen 3 de 3
    • If the broken key(s) are white, remove the set of white keys with the broken piece.
    • If the broken key(s) are black, remove two sets of seven white keys. This will reveal the set of black keys, which are twice the length of the white sets.
    • The key sets can be troublesome to remove. To remove without further damage, make sure to lift up on the top part as shown and push the bottom part of the keys towards the bottom of the keyboard to unhook them individually.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Will Wright
Miembro Desde 10/23/24
369 Reputación
2 Guías creadas
Equipo
Cuesta, Team 10-4, Krynen Fall 2024 Miembro de Cuesta, Team 10-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G4
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 93
