Introducción
The Canon Selphy CP910 is used to print pictures from a camera and WiFi connection. If there are any issues with the LCD screen of the printer, it may be necessary to remove it. For information regarding troubleshooting issues with the Canon Selphy CP910, go to Canon Selphy CP910 Troubleshooting.
Contact the manufacturer for inquiries about receiving parts of the Canon Selphy CP910.
Qué necesitas
Turn the printer over.
Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
Once you detach the top, turn the device around.
Use the PH0 screw bit to remove the five [size] screws.
