Saltar al contenido principal
Canon PowerShot SX520 HS Lens Replacement
Qué necesitas
  1. Canon PowerShot SX520 HS Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Lens Replacement: paso 2, imagen 1 de 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Lens Replacement, Back Face: paso 3, imagen 1 de 3 Canon PowerShot SX520 HS Lens Replacement, Back Face: paso 3, imagen 2 de 3 Canon PowerShot SX520 HS Lens Replacement, Back Face: paso 3, imagen 3 de 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Lens Replacement: paso 4, imagen 1 de 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Lens Replacement: paso 5, imagen 1 de 2 Canon PowerShot SX520 HS Lens Replacement: paso 5, imagen 2 de 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Lens Replacement: paso 6, imagen 1 de 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS Lens Replacement, LCD Screen: paso 7, imagen 1 de 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS Lens Replacement: paso 8, imagen 1 de 1
    • Carefully pop out the LCD screen with your fingers.
  9. Canon PowerShot SX520 HS Lens Replacement, Metal Plate: paso 9, imagen 1 de 3 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: paso 9, imagen 2 de 3 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: paso 9, imagen 3 de 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
  10. Canon PowerShot SX520 HS Lens Replacement, Lens: paso 10, imagen 1 de 1
    • Unlcip the large cable by pulling up on the metal part with your finger.
    • Slide out the 2 smaller cables with your fingers.
  11. Canon PowerShot SX520 HS Lens Replacement: paso 11, imagen 1 de 1
    • Lift up the lens by grabbing the sides with your fingers.
Conclusión
6 personas más completaron esta guía.
Lisa Choe
Miembro Desde 09/22/15
460 Reputación
3 Guías creadas
Equipo
Baylor, Team 4-4, Williams Fall 2015 Miembro de Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Miembros
6 Guías creadas
Un comentario
guide is unfinished; dropping to the point of lens group extraction without going on further. I found it, useless.
SimoneGallina - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 3,278
