Saltar al contenido principal
Canon PowerShot G12 Battery Replacement
  1. Canon PowerShot G12 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the camera over with the bottom facing toward you.
    • Place your thumb on the compartment labeled "card/batt open" and slide it outward and up, exposing the battery.
  2. Canon PowerShot G12 Battery Replacement: paso 2, imagen 1 de 1
    • Push out the red latch to release the lock.
    • Remove the battery.
    • Note the battery's position in the terminal.
  3. Canon PowerShot G12 Battery Replacement: paso 3, imagen 1 de 1
    • To insert a new battery, push the red latch out.
    • Insert the battery into the terminal, ensuring the positive end marked with a red arrow is facing downward.
Conclusión
Equipo
USF Tampa, Team 1-5, Leahy Winter 2015 Miembro de USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 1,333
