Saltar al contenido principal
Canon PIXMA MP620B Scanner Light Replacement
Qué necesitas
  1. Canon PIXMA MP620B Scanner Light Replacement, Separate the scanner cover from the rest of the lid assembly: paso 1, imagen 1 de 1
    • You will have to pry off the glass cover lid. There are no screws that you have to worry about. Just insert a spudger into the crack between the glass lid and black base as shown.
  2. Canon PIXMA MP620B Scanner Light Replacement, Lift the glass cover of the scanner and take out scanner light: paso 2, imagen 1 de 1
    • After lifting the glass cover up, the light assembly will come free because it was only held in place by the glass top.
  3. Canon PIXMA MP620B Scanner Light Replacement, Unplug the white wire from the scanner light assembly: paso 3, imagen 1 de 1
    • Now that the scanner light assembly is free. Lift it out of the scanner bed and unplug the large white wire that attaches it to the rest of the printer.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-21, Maness Fall 2014 Miembro de Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 2,722
